Hello All,
I am trying to trigger an alert using nodejs/pdjs and hitting the Events API v2 endpoint but keep getting back this error message
status 200 OK
"error": {
"message": "Not Found",
"code": 2100
Below is what I am doing, please correct me if I am using the api the wrong way.
HTTP-Method: POST
const alertUrl = https://events.pagerduty.com/v2/enqueue
header
'Content-Type': 'application/json',
'Accept': 'application/vnd.pagerduty+json;version=2',
'Authorization': 'Token token=<MY_API_USER_TOKEN>',
'From': <MY_EMAIL>
body:
payload: {
summary: 'This is a test alert,
timestamps: '2015-07-17T08:42:58.315+0000',
severity: 'warning',
source: 'sample source test local environment',
component: 'mysql',
group: 'prod-datapipe',
class: 'disk',
custom_details: {
'free space': '1%',
'ping time': '1500ms',
'load avg': 0.75,
routing_key: <MY_INTEGREATION_KEY>,
dedup_key: 'srv01/mysql',
event_action: 'trigger',
client: 'Sample Monitoring Service',
client_url: 'https://monitoring.service.com',
links: [
href: 'http://pagerduty.example.com',
text: 'An example link.',
images: [
src: 'https://chart.googleapis.com/chart?chs=600x400&chd=t:6,2,9,5,2,5,7,4,8,2,1&cht=lc&chds=a&chxt=y&chm=D,0033FF,0,0,5,1',
href: 'https://google.com',
alt: 'An example link with an image',
sample code:
import { api } from '@pagerduty/pdjs';
const pd = api({ token: <MY_API_KEY>, tokenType: 'bearer' });
async someFunction() {
const { response, data, next, resource } = await pd.post(alertUrl, { headers, data: body });
return data;
someFunction() // returns => error code 2100 with message not found
I am trying to run the above function in a NestJs application, oddly when I try to run the above function using postman or curl; it works.
